Brake Vacuum hose
Mar 18, 2003
1,249
In oncoming traffic
I think its this one, if so then i thinks its just held on by those one use clips, just use jubilee clips to replace like top clip on mine!
The hose above (with the jubilee and 1 time use clip) is attached to the hose i have a replacement for (the forge link).
Should i just move the hose with the jubilee onto the part where the 1 time clip is?
I hope this makes sense.
Cheers for your help
Rich
Mar 18, 2003
1,249
In oncoming traffic
Slightly clearer. A, is the stub on the intake manifold B, is the hose that goes to the servo, C and D, go somewhere else? It looks like the forge hose is the lower one with A and D attached. Can I put these anywhere you can see them Junior?
Mar 18, 2003
1,249
In oncoming traffic
Ah, I see, I would think so! Gonna pull mine apart later to neaten it up a bit! I have a look, I always thought that servo was conected direct to manifold but it seems not, wonder what C and D are?
Well i've replaced the small coolant hoses with blue hose but no-one does the large ones like you say.
It's a shame the brake vacuum hose only comes in black and the turbo hose only comes in red but you can't really see them.
Right, well i fitted it at the weekend.
I'm gonna try to explain the best i can how to do it.
I would recommend taking off your charge pipe for ease of access (i didn't).
You have to undo A and D which were one time use clips on mine which are a complete pain to get off.
Then where the replacement hose is attached to the hose above (between C and B) cut the connecting rubber as close to the lower hose as possible.
The hose you're replacing comes off easily off the manifold but the lowest connection is tricky, i would recommend using a stanley knife (carefully) to cut the hose off.
Then it's just a case of fitting your new hose with new jubilee clips (13mm - 20mm).
One thing i will say is, when getting the lowest part of the hose off be careful not to split the vacuum hoses that attach underneath the manifold. I did and it was a pain to sort out.
Borrowed Picture (hope you don't mine)
I'm pretty sure you can connect the B hose straight onto the C bit, so you could run a silicon hose all the way from C upto the top left of the bay where it connects to. My engine bay's getting there, i'll get a couple of pics after i fit my oil catch tank which probably won't happen until next weekend.
