Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
has anyone done a brake upgrade ive upgraded to the corrado g60 280mm brakes but wouldnt mind some 2 or 4 pot calipers has anyone done this and what calipers etc did you use?
With your G60 hubs the easiest upgrade would be to go for mk3 ibiza cupra R brembo 4 pots and the 305mm 4 stud discs
Easiest as they will bolt straight on but not the cheapest :-(
Is your master cylinder standard or a 23mm g60 item? i say this as you'll need a large M/C if your going to push more fluid!
