Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
jenk said:The 256's are cack, mite be fine for a 1.4 though
roly said:i've got a set of 20VT calipers, pads, hubs, carriers and bearings sat at home if there any good to you
£100 delivered
andyj said:yup they'd fit yours, you'd just need a new set of 280mm (Mk2 Golf G60) discs to fit with them, about £60 all in from GSF/ECP
2.0 8v brakes can be used, but you need to get a 280mm brake carrier, which will space the calliper out enough to fit over the 280mm discs.
andyj said:that's what ya get when ya sit in front of a PC 8hrs a day with email notification turned on !!!
