monkey73
Hi all,
Seem to be having a problem changing the brake switch which I know should be simple !!
Had a problem with ALL the brake lights not working. Checked the fuse and all the bulbs (only replaced them last week and seem ok) but still have a problem.
Looking on the forum, other threads seem to point at the brake switch.
Tried to change it following the guide, but this is where I find another problem.
When I connect the new switch to the electrics all 3 brake lights come on and stay on !
Then fit the switch and the brake lights are all still on ! Tried starting the car, pressing the brake pedal but no difference - the brake lights remain on contstantly.
The "pole" on the switch is now pressed all the way in (assume it's broken now?) - but I've got a spare.
Not sure if Im doing something wrong or if there's some other problem ?!
Any suggestions ????
Its on a Mk 4 Ibiza by the way.
Many thanks.
Robb.
Many thanks.
Robb.
