Brake Servo Question,
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
rang seat dealers with reg plate no for my 1.8t facelift cupra asking for a replacement servo unit,
the part number they gave me was
1J2 614 106 D
the part number on my servo fitted is:
1J2 614 105 D
question being i can get hold of a new 106D for £85 instead of the seat price of £225, but why has my servo thats fitted showing 105 D,
would the 106 D be a revision,
Help much appreciated, as soon as i can clear this i'll get one because not having power assisted brakes isnt good and im getting bored of it sitting on the drive,
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
In theory 105 and 106 would mean o/s and n/s so guessing lhd and rhd.
But dont have ETKA to check.
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
Realistcally if seat gave me that part no from my reg plate, would it fit in place of the 105D thats fitted to my car or would you say im taking a gamble,
I'll be honest looking at the amount of space behind the engine ans the size of the servo, its going to be one hell of a squeeze getting it out :(
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
You have to drop the engine down on a 1.8T or diesel, no two ways about it as it tucks behind the suspension turret. You have to get it our far enough to clear the pedal rod.
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
would you say thats possible with a set of axel stands and a couple of jacks? or is it a hoist job,
cheers for the help
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
bit of an update really,
Servo removal wasnt as much of a task as i thought,
its out with the engine in situ, the dogbone, driverside and gearbox mount were all removed and dropped, with the engine supported on jacks,
turbo chargepipe mastercylinder, exhaust and support bracket to intermediate pipe had to be removed engine dropped a good 8 inches, allowing just enough space to remove servo,
im tempted on writing a guide with pics, would this be of any use to anyone?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
It would be a massive help and would be much appreciated too
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
Just a few pics to show where im at, the new servo is in plumbed up but just needs to be bled,
it is possible to remove the servo with the engine in the bay but lowered by a good 8-9 inches
excuse the mess, typical engineer by trade, :p
cuprasbd
Great thread, may I ask why you changed it? what fault did you have with it? I suspect mine has gone too :cry:
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
it had an internal vac leak on the servo, so it'd hiss when you press the pedal, and you'll only have about 35% braking efficiency,
same signs as a vac leak but stiff pedal and bugger all braking
cuprasbd
Ah, Ive lost my pedal and no fluid leak!...mind boggles :confused:
lol
Feb 28, 2010
1,367
Southampton
Ohhh hissing when the pedal is pressed is the servo?!
What is hissing with no foot on the pedal, hissing stops when brake is applied, but a bit more play in the brake pedal?!
Could mine be a split brake vac pipe?
