When the weather picks up a little in a few weeks, I plan to carry out the following:
Renew front disks and pads
Renew rear disks and pads
Remove all the calipers, strip down, clean and grease the sliders.
Repaint calipers
New fluid and rebleed.
A few questions
1. Am I right in thinking that like most of the VAG cars I've owned, the rear disks have the rear bearings pressed in? Easy to do?
2. Are there any off the shelf braided hose kits for the mk2 ibiza? or is it a case of adapting other VAG kits?
3. Any pad recommendations? I'm off to the ring in the summer hence the reason why I'm making sure everything is in top notch condition, so I want a pad that will take a bit off stick, but 99% of the time will be used on the road so must work well from cold.
Also while everything is apart, might takle suspension, what would be peoples recomendations for a suspension kit? Comfort is important to me, would like to lower it a touch also, but the main reason is sharpen it up.
Also, front tyres will need replacing shortly, what decent, maybe track orientated rubber is available in 195/45R16? Maybe toying with the idea of dropping to 195/40R16 for a bit better acceleration.................
Hmm decisions decisions.
Repaint calipers
A few questions
