brake pads
marshy19
hi there,
Recently brought myself an 03 cupra R and the brake pads are worn. Just wandering weather there is a type of pad someone would recommend using. Im still using standard discs if that makes a difference to what i buy.
marshy19
ok thank you
Theres loads of different one i have seen. Some have the wear sensor wire and others dont. Does this matter.
thanks again
To be honest the sensor's don't work properly anyway as the pads don't always wear evenly. All you have to do is connect the two wires together as far as i know to stop the light coming on the dash. The Ferodo's don't come with the sensor wires but they are well worth getting.
