brake pad warning light on dash
synchro
hey guys
i recently got the brake pads on my 2001 mk2 toledo tdi se replaced.
the pads are now fine, but the warning light on the dash is still on
what needs to be done to disable this bulb on the dash?
thanks
ed
tomegan09
HI
I think that could be a low brake fluid. That happened to mine and the ended up been a leak in the brake line.
dizzydiesel
Mine is exactly the same.
2001 mk2 toledo. Changed the pads, 1 week later the light came on. I checked the fluid level - it's ok. Dodgy sensor in the pad?
Any ideas?
Feb 26, 2009
5,275
Wolverhampton
I believe brake pad sensors work on an open circuit, so connecting the two wires should get rid of the warning. The brake fluid warning light should be a different one, as that is an MOT failure if it doesn't light when the ignition is turned on.
seattolsports
I have the same problem after Sh*ifit installed new front brake pads on my P plate Tolly. I topped up the brake fluid and the light went out. Seems fine now
