brake lights help
chavlad
help please just been out tonight and the top brake light stays on and the two normal ones dnt flash when pres the peddle i checkd the fuse and its fine what causeing this problem
chavlad
dont worry peep was brake peddle switch sum how cm bk to far frm peddle now sortd
chavlad
i fixed the existing one on mine it just poped back sum how all i did was twisted the white bit to the left to pull it out then pushd it further in to it contacted with the peddle then twist it to the right to re lock it in place n it was sortd then no problems since hope this helps
