Brake judder, funny noise and not feeling right?
fran1987
213
hull
Hi everyone.
For a while now I have had a funny rubbing/scuffing noise from the front passenger wheel when turning right. Had a quick look and can't see anything obvious rubbing on the wheel and nothing is catching, I thought it could maybe be a ball joint or wheel bearing?
Also Iv been having some bad brake judder along with pulsing as if the car is braking and releasing and braking again while I'm braking. While I'm driving at slow speeds to it feels as though the car is skipping almost like there's a small bar on the front wheels and its fighting to go right, does this sound like warped discs?
There doesn't seem to be any boost issues or anything like that and tend to notice it more at slow speeds.
Sep 18, 2009
2,443
Shropshire
Warped discs aren't as common as you think, check your steering rack and track rod ends to see if there's any play in it. If there's any play then you get vibration under breaking through the steering wheel ?
