Brake disc wear
Snappy Larry
21
Anyone know the maximum recommended brake disc wear limit.
The stealer is telling me my discs are worn and need replacing but having inspected myself there is a small lip but not excessive in my opinion.
I have a micrometer, just need to know the manufacturers recommended minimum thickness.
Thanks.
P.S. it's an 09 FR diesel.
Rusty2k
713
137
Recommended minimum is 22mm for the 25mm discs and 19mm for the 22mm discs.
I suspect you'll have the 25mm discs.
richicupra
1,823
9
Common dealer trick, "Your rear pads are over 75% worn Sir, but conveniently we have a spare half hour in the workshop if you would like us to replace them while your car is with us..."
Pointed out when I picked the car up there appeared to be a lot of pad remaining, cue some red faces and excuses. 5000 miles later got round to replacing them myself and there was still about half the pad material left.
