Brake conversion help
Kendo
The Kit Car Man
May 15, 2005
329
erskine
Can anyone help with a definative step by step guide on how to carry out a brake upgrade? Tried posting on braking sub forum without much luck.
I have a MK4 Ibiza FR Tdi and waiting to go on are
1. Audi TT callipers (painted red by myself).
2. 312mm Cross grooved and drilled Dubsports discs.
3. Cupra brake hoses.
4. Sports Pads.
What tools will I require too?
Cheers in advance folks.
gazjones
hey my guide. im not sure you need to change the hoses i id a 312mm conversion on a 100pd that had a 288mm conversion and hoses were fine. will just require bit more bleeding if you change the hoses. give yourself around 3 ours to do the job. also mastercylinder is bit of pain to get to needs the vac lines unpluging to the vac box on driver strut.
