Brake clearance on Ronal's
Grayboy
970
Beckenham
Hi does anyone know if you can fit Porker or Brembo caliper's behined the std 16in Ronal multispoke's running 305mm disc's??
I know they'll fit inside the diamiter of the wheel I was just wondering if there's any clearance problems on the back face of the wheel/spokes??
123robbo
My 312mm TT brakes fit under them. However, the wheel weights wouldnt, yes it was THAT tight and by the spokes there was maybe 1mm gap. I have Seat sport Oz super t's now and there is LOADS of room.
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
The problem with brembo calipers is that they are very chuncky!
Greg managed to get AP Racing ones behind the ronals but that was after shaving a bit off the calipers and brackets and 10mm spacers lol.
I have never thought about seeing if my ronals would fit over the brakes but the spokes are thick on them.
gregclarks
Trying to Resist ARBs
May 31, 2006
314
Anything will fit, if you have an angle grinder and a hammer, precision engineering at its best.
Rub87
16
Got the same problem..
This weeknd I tried some rimms to see what would fot.. non did :/
I've tried my 16" toora wheels (et35) I have now (8 spoke if i'm right), spokes where too far inwards, also the evo1 rimms don't fit.. Is there a difference between evo2 rimmes and the mk3 cupraR ones? I see they also both have an et of 35.. will evo2 rimms fit? I also had a set of the "GenerationG" rimmed (the yellow ibiza's in Belgium were you also get a G shock watch when you bought one) but sold them shortly..
Was also considering using the golf3 gti 20th aniversery edition 5 hole hubs, because i've a new set of the original leon 180bhp 20vt 6spd rimms as they first came out (very fine spokes) that are really nice rimms..
