Brake bleeding
Aug 7, 2009
1,395
Manchester U.K
Anyone ever had to bleed the abs pump when the system has run dry, i know you use VAGcom but some say open bleed nipples and do it again, im sure you would just activate the pump then do the normal method? as its purged the pump of air?
jezzag60
The newer version of VAG com guides you through what to do, can't remember if the old one does though. Don't forget the bleed nipples on the master cylinder, air trapped there is often the cause of a bad pedal!
There is a thread going about this on the Ibiza Mk3 section which may help you.
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
get it pressure bled i had mine done i cudent pump it out with the pedel or a self bleeding kit cost me 20 quid at a garage
