Brake bleeding
myseatcupra
ibiza fr tdi
May 14, 2007
791
cardiff/penarth
the easiest way is get an easy blead kit from halfords. makes it so easy. just fill it up conect it to your servo. then fit the presure pipe to you wheel valve
and it pumps it through. easy as
myseatcupra
ibiza fr tdi
May 14, 2007
791
cardiff/penarth
if you dont wana do that. get someone in your car. open up the bleed valve as they. press down on the brake peedal. then lock off. then let the pedal up. then do the same again till.. theres no more bubbles. but it is a pain doing it this way
kiearn
156
Norwich
One man kit really easy just connect up in correct order, pump pedal a good few times and until no air is seen in connecting pipe and tighten nipple. Best to still use two people if poss saves any probs if seal isnt great (dirty nipple)
