I've noticed the air-con is definitely blowing cooler since I had my new fans on Friday.
I think it's linked. There's a few threads about this now (assuming you had the same
problem as the rest of us). The radiator fans have two speeds, slow for air-con, fast for cooling the rad (hey, I sound like an expert now - just passing on what I was told). The fuse for the slow speed is known to blow, resulting in needing new fans.
If your fans needed replacing, it might have been due to this. Even if this wasn't the
problem, new fans should
help improve the air-con performance.
