bose speakers and sub
mr.leatherday
68
Chesterfield
hi all just looking on ebay and seen a audi set of bose speakers, sub and amp will these fit in my 05 leon and if they would is it the a3 or would any audi set fit many thanks martin
warren_cox
Back from the dead
Not so sure all the speakers would.
Audi front tweeters in the Bose system are located in the A pillar, not in the door skin, and are complemented by a centre channel located in the middle of the dashboard to rais the lower midrange out of the footwells.
The door woofers should be a pretty much straight swap.
There are then two rear woofers in the rear doors (which again should fit), and a sub mounted in the boot over the nearside left wheel arch (when I say sub, I mean almost a sub - more bass than components, but if your used to a REAL sub bass you could never call the Bose unit a TRUE subwoofer).
Don't know where the amplifier unit sits, never found it to date.
Be warned, some that are removed sometimes suffer a bit in the de-installation process and can be problematic. Its a decent sound against basic OE kit (for the lazy arse like me), but its no match for a well set up Alpine set up.
Deleted member 20376
ive been looking for something like this. in the past ive replaced speakers with alpine and infintiy and so on in my older cars. but with my lcr the sounds sounds good the all standard, i heard the bose kit fits straight in but how does the sub speaker box fit do ya need to run wires and so on.
SalSheikh
Under the Hood
Sep 2, 2009
2,760
Midlands, UK
i dont think we have enough space for the sub to sit behind the rear wheel arch?
i may be wrong...looked at my bro's S3 and then mine when i did my rear washer pipe leak fix and i didnt think it would fit.
Feb 22, 2009
3,618
South Wales
cupraslayer
I want more bhp
Feb 8, 2008
1,543
northampton
Wow that is expensive!!!! Lob out the spare wheel . Build a box and sound deaden it . Plonk in a jL w12 sub and done! 1/4 of the price. :)
Mar 3, 2009
823
Hinckley
amp is wedged up in the right wheel arch area but a lot of trim needs to be removed. Its a lot of hassle to fit it compared to aftermarket for no gain over aftermarket
br0wny21
the amp wont work because it will have a wiring loom in the car it came from because the connections are different its not like a aftermarket amp where u have a power a remote then your phono leads its just one connection for the bose
