Borbet A's on mk2 ?
rockstone187
Hi I'm picking up some s/h Borbet A 16 x7.5j et45, can any of you let me know if I will need spacers for these to go on a seat ibiza mk2 (1998) and what size if any? any recommendations where to buy them from would be good as well if needed
Thanks in advance
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
andy is 100% right go for hubcentric, i got some crappy ones, and i swear it takes me 30mins to put my rears back on (cos of the stupid spacers)
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
Suj.. next time you take a wheel off (or wheels) put a few blobs of sikaflix/tigerseal on the spaces (hub side not rim side)and once on they will/should stay in place next time ;)
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
that's ingenious brummy :) taa mate! it's sooo annoying normally lol
rockstone187
Back again.
Picked up the wheels, which will need a light refurb (probably will DIY to a mirror finish (1st time doing it, but wil take my time) dont want to spend 300 sheets to get them done. Anyway, the wheels as said before are et30 16 x 7.5j but are fitted with 205/45 tyre. I presume i will definitely need to run with spacers (any other good ones other than FK or H&R for cheaper, or should i just bite the bullet). The real question is that with the greater tyre width will 5-10mm spacers do?
rockstone187
will it not rub against anything or damage anything if i dont run spacers? et30 on alloys on mk2 et 35-38?
