boot wont shut
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
the striker plate most probably needs adjusting.. if the 'lock mechanisn' is not loose..try the part it locks on/into (bit on the main body of the car.. mine was always doing this when I first got the smashed boot opened....
big Tor-X driver or a flat bladed screw driver will tighten it
Dec 31, 2005
1,856
London
ihi ibiza for a daily driver? do you **** gold nuggets?
more details?
I remember seeing a yellow one on piston heads with low mileage but white alloys, plus that black one with the strange bodykit on
Gm8
Jun 13, 2007
661
Glasgow
same prob on my mk2 , just release the screws/allen bolts on the pin as brummy said , it will move , pull it slightly toward you and tighten up . job done .
Feb 1, 2007
1,293
gloucester
the pictures dont do the car justice , the arch extensions look quite good on the car , the front bumper looks good as well , looks like a rs4 bumper , lines up like the oe bumper as well , might just end up ripping it all of though , and put it totally back to standard body work wise
