Boot not opening (no motor sound)
woozyuk
80
erith
It was working properly until mid day Saturday. Managed to get the boot open by climbing inside and taking the trim off and moving the white lever to open it manually but i dont hear the motor that used to unlock it when lifting up the seat logo on the boot. Wires look fine. and they were pushed in properly. please help. car is a 2013 1.4 Toca .thank you
Reactions: LeighPing1
everson38
470
35
walsall
Common problem with VW boots opening. On my moms car she had an intermittent. It would stop working and then suddenly come back all fine. In the end had to get it into Seat. There was corrosion on on the connector terminal. So try unplugging each component and follow wiring back and unplug any others and check in there for and signs of Corris on or water getting in.
Sent from my SM-G900F using Tapatalk
woozyuk
80
erith
im not going back to SEAT. i had the cars last major service in 2018. had a new water pump and timing belt all was very espensive. then the coolant was leaking all over the engine and overheating light would come on kept having to top up the coolant tank. then when they eventually agreed to look at it they said the water pump was faulty and replaced it. i still have the coolant alarm come on randomly every few weeks and the car doesnt start up like it used to, its very lumpy and splutters and can stall. happens more on hot or cold days. ok once engines warmed up. now i have this boot issue. i love the look of the cars but all the issues have put me off the seat stealers.
the boot is now a nuisance as i carry things in it a lot and have a spare wheel in it. i need someone that can tell me what to do that has had the same issue
RUM4MO
8,078
1,106
South Scotland
Maybe use the search function as this has been happening to a lot of people with this model as well as with previous models, mainly SEAT though, VW seem to have a better record on this problem.
woozyuk
80
erith
iv done a search before and its useless. just a post about a 2010 model. They replaced the microswitch/badge. But how do i know what component is at fault? the wire? the lock mechanism? the microswitch? All looks visualy fine. No motor sound when pressing the microswitch whichi can hear being pressed.
Lucero
63
I had mine apart for a similar issue and honestly, it's not worth the hassle beyond just replacing the unit with a new/used one and getting on with your life :moon:
everson38
470
35
walsall
I'm not saying go to seat. But I was in same position. Everything looked fine I even looked down the the wires from the plug end and it seemed okm but turns out there was corrosion inside. So I'm assuming the they opened up the plug connectors heads and the corrosion was a little further down where just looking at it from the top you couldn't see.
everson38
470
35
walsall
Hey mate so how did you get on in the end with your switch and no motor sound?
Sent from my SM-G935F using Tapatalk
everson38
470
35
walsall
to all, in the end the car when back to seat. They rectified the problem. They said it was a broken wire. It appears the broken wire was inside the black connector block in the boot (as I said the one i did not know how to open). The technician said he has hard wired it now, so completely missed out the connector and crimp connected both ends. This has solved the problem for now. See pictures of before and after (repair).
Alittle annoying that I just needed to get into that black connector and I would of seen a broken wire, but even now I don't no how it is clipped together, but you live and learn and hopefully someone can show me how to open it lol.
Sent from my moto g(8) plus using Tapatalk
