Boost readings?
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
Ok just now fitted my boost gauge all seems to be working ok but just want to check what reading i should be getting? my car is a mapped 20VT. Any ideas please :help:
cupra_brown
324
so you done it then!
how did you get on?
mine readings seem to be like this....
on floor planted....boost shoots up to 25-27psi then drops straight away to around 18 psi and then holds at that...
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
ok, on my gauge it has 30 to 0 inHg than from 0 to 30 psi. Car switched off its 0 switch car on and it sits at about 25-30 inHg when i floor it it peaks at about 18 or so? holds about 10 maybe a bit less. To be honest i only had a quick drive, i will have a proper look at it tomorrow. Im not sure what the inHg is? :redface:
cupra_brown
324
the inhg is the vacuum i do believe....
my gauge has only got boost psi on it so i couldnt tell you if your is right or wrong. I did read that you gauge should go to the inhg side when you start up the back to 0. Then obviously when you floor it , it should go the other way!
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
well it is pretty much doing that, i think it was sitting around the 0 when im driving, cant remember? i will try and have a proper look tomorrow. Thanks mate.
Im pretty pleased with my self for getting it fitted, it looks good and im glad i spent the extra cash on the nomad pillar. Now i need to think of my next project :D
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
be negative pressure at idle
up to 0ish when normal driving
anything from 8-20 depending if your mapped etc etc etc
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Well mines at idle is -8 vac
On full trottle, its at 1.2 bar ( 17.40 psi), then holds at 1 bar (14.50psi)
chriswilks
Astra CDTi track car
Jun 3, 2007
330
warrington cheshire
that sound bout the same as mine!!was really worried mine was dropping for some reason but mine does the same although it goes upto bout 1.4 bar then settles at just over 1bar!!
my boost guage brings up max reading when i turn of ignition which is bout 1.4 bar which was confusing.thats my concern over anyway!!:)
Big_daddy
Oct 20, 2006
3,930
Brummy
what you mean when you 1.4bar when you off the ignition, mines jumps to zero when i turn it off :confused:
chriswilks
Jun 3, 2007
330
warrington cheshire
its a bit weird....its programmed to show the highest reading after every drive!!!quite cool but quite pointless....its wired in.one of those annoying ones on a servo but it lights up red at night which looks ace!!!
danieltm
Bit of Jabba magic!
Aug 26, 2006
796
Norwich
Ok, peak boost is about 17-18 then holds about 14-15psi. normal driving is around the 0. I think this is all about right. need to be careful tho coz im finding myself watching the gauge and not the road! :drive2:
Big_daddy
Oct 20, 2006
3,930
Brummy
Same here, ive moved my gauge from window pod into centre console, now the passengers can watch :D
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
Got a non mapped LCR, with -30inHg when idle, 0 when off and bout 0 on normal driving, (motorway using harly any throttle) the spikes at 12 holds bout 11psi on full throttle, falling to 10 towards the red line.
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
weird that these seem to spike and then hold
always learned there was something wrong if it was spiking, turbo cars ive had just hit the max and hold.
hmmmm
Big_daddy
Oct 20, 2006
3,930
Brummy
hmmmm
got feeling that these vacum gauges are not that accurate compared to the digital readings from the ecu.
