Its impossible to tell you with such vague information if you have a boost problem however, it is normal for boost pressure to drop around the higher rev range.
I have a K03 and it peaks at about 21Psi at around 3500 revs and drops to just 10Psi at 6000 revs.
Was playing with the idea of changing the actuator for a forge one but it seems that the general concencus is it will cause boost spikes and i will see my internals come through the bonnet!
as johhnyblease wrote..he has the same numbers as yours with k03..
i also get about 20 psi on 3000 but i get around 12 on 6000 mark,,
i think u should be able to have more boost in upper revs with k03s...
