Boost Logging..
flooky
Ive had a look and see bost logging is block 115 but where in vag-com is this?
i cant find it, im running version 311.2-n
cheers
flooky
sorted thank you! yeah i got the full version from my next door neighbours...
how will i know if my reading is fine? what should i be looking for?
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
if actual (the right column) is equal or slightly above the requested (the left column)
standard boost is about 1500mbar at around 3.5-4krpm and it'll slowly drop down to the redline
remapped will be like 2000mbar-2500mbar depending on the map
u deduct 1000mbar from the vagcom result to know the actual pressure 1000mbar is 1bar of boost (14.5psi)
flooky
ok thanks, will give it ago in abit and see what i get.. cheers!
flooky
well i got 1510mbar at 3240rpm and died off from there really. pretty sure there is a leak on one of the vacum hoses which im looking at tomorrow.. cheers for your help man!
