Boost logging
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
think i got boost leak where when i foot down i could here the turbo but the car not launching right. the bost gauge works but there is no pull when you ground the foot.
i got vag .com
any1 could tell me how to monitor the boost? what readins are normal?
(leon 1.8T 180bhp - vipper induction kit - exhaust system.)
gazjones
there will be actual v requested, requested is what the ecu wants the turbo to deliver. if they are pretty close all is ok, you can log them then put them both into a graph and both lines should look the same if all is ok
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
cheers dude...
so vag.com will read about 1500bar....
i always have a feeling that the car isn't that quick....will have to do some testing and see if i get about 1500 on that block....
Big_daddy
Oct 20, 2006
3,930
Brummy
Hi when i logged the boost, 2nd gear, the 1st colum one showed a higher reading than the other colum. but as i went through the rev range, they wer equal but a 1 second gap. there were a few spikes on the 1st colum.
The car get stuck at 6000 rpm, it dosnt die out but stays there constant at 60mph, with my foot mounted to the ground.
Bogwoppit
1,085
Lincs
The best way to do a log is find a clear stretch of private road, pull away slowly and short shift to 4th gear, start the log, then give the car full throttle from about 2000rpm to 6000rpm. (This will be over 100mph so find a long private road).
It is odd about the car staying at 6000rpm though.
Big_daddy
Oct 20, 2006
3,930
Brummy
I use have that problem before where the car use to jam up at 5000rpm.
the fault was fault lambda sesnor, replaced that with new maf meter as well. the car then use to go correctly but no feel with turbo running,
then open circuit come up for the N75 valve, replaced it a used n75.
the car then use drive nice and pick up with some wheel spin. with few popin from the exhaust as well.
then l8r in the week the car gone stop pulliing as it should, couldnt feel the turbo kickin at low rpms on when it hits 4000-5000rpm. Now the car some time jams when it hits 6000rpm
