Fitted my boost gauge today
Teed it off the DV vac hose
On idle, its sitting at about-0.8 bar, is this normal??
In gear, full throttle,it goes up to 1.5 bar and then starts to tail off to about 0.9 bar eventually
does this sound right for a revod 1.8 20vT cupra?
it doesnt seem to hold at any sort of specific point, like im led to believe it should, it goes right up to 1.4/5 bar then slowly creeps right down
is this normal, or is the OEM dump valve leaking boost away??
only mods are the revo and the boost gauge!
is it worth changing the N75 for a J, and doing the N249 bypass?
cheers
stu
cheers
stu
