sparkyc
185
just fitted my boost gauge and wondering where have you run your pipe work to stop it getting so hot? i'v taken my feed from the top of the dv and struggling to keep it away from everything. also the pipe supplied is really weak and collapese around 15 psi, any reccomendation on replacement pipe? cheers in advance
I'm using SFC 4mm silicon pipe, took mine off the FPR to manifold pipe as I was told its better to run it as close to the inlet manifold as possible.
This is how i have ran mine
I done mine the same as Lee's and T'd it in same place although I'm putting 2 extra take offs on my manifold when I fit new one so I don't have to T into anything :)
ok cool so looks like i gotta repair the hose going to dv and get some longer silicone pipe then!
replace as much piping with silicone as possible, if you get a length of 4mm pipe whatever is left can be used to replace existing FPR line, etc.
ha ha yeah i just brought some blue 4mm silicone from a big auction site, and a hose joiner to repair the dv pipe! cheers for your help guys
If you buy some 5mm silicon pipe you can put a new colourful piece of the top of the DV to the N249 instead of using chopped up original bits.
Even do the N249 bypass if your feeling more confident
