Boost gauge hose on DRIVERS side?!
Engram
Hello!
Has anyone here managed to run a boost gauge hose through the grommet on the drivers side of the car? (The one the bonnet release cable uses).
In fact.. has anyone managed to run anything through that side?
If not.. do the boost gauge manufacturers give you enough hose to get through the passenger side and then under the dash to the drivers side A pillar? (Specifically thinking of J3 gauges).
Ric 2001
Need an ID-ten-T form
Buy some vac tubing fron forge..... http://www.forgemotorsport.co.uk/content.asp?inc=product&catalog=0022VT
Housing wise I got Nomad A Pillar with a double din holder from AwesomeGTi..... As you've seen in your previous post abit expensive. but these are 60mm gauges but house fine in the 52mm diameter hole.
Standard boost... doh. Need a new picture.
