I have a 2003 1.8t toledo, engine code AUQ with the following mods, Chipped by Chipsuk, i have fitted 3" downpipe and de-cat, panel filter with cold feed, 710N valve and had a N75 race type i think F. I have also just got the car converted to LPG, the gas software uses the opening times from the injectots to know how much gas to put it. The problen is the Gas software thinks my injectors go to 100% duty cycle at approx 5k rpm, do you think this is possible? I have alwasys noticed that the car doesn't pull well at 5-6k even on petrol,I turned the boost down witha mbc and the car is slower but can rev alot harder up at the top end, but obivisloy is missing alot of boost low down, set to approx .7bar.
My injectors shouldn't have maxxed out, would a 4 bar FPR sort this out.
Ivan
Ivan
