boost controller ?
cawsey18
158
hi there.
right , got myself an amd remap yesterday in my mk1 fr. Love it plenty of power and nice and drivable . Only thing is i wouldnt mind dropping the boost occasionaly back closer to standard boosting levels . Are these extremely dangerous to the engine ? if not what is good to go for , any ideas would be great cheeers , Also if these are out of the question anything else that woud be ok to use cheers
D.K
LCR 225
Oct 24, 2007
6,408
se london
The best boost controller is your right foot, DONT fit a boost controller you will give yourself no end of problems.
tripdiesel
Leon Cupra R 225
Mar 21, 2009
162
Isle of Wight
I believe REVO do a switch which allows you to revert back to a standard map when required and then change back again when you want a bit more power, have a look at there website, what map did you go for?
cawsey18
158
ok then so a boost controller is out . D.K , do you know if they can adjust the map . I think its just im not use to the power at the moment lol, Abit of a whimp at the mo i know lol but i have just come from a 1.8 focus . Can they play around with it and give me abit less than i got yesterday then ramp it up again once im use to that ? cheers Dont get me wrong though i love it !
D.K
LCR 225
Oct 24, 2007
6,408
se london
They might be able to tweek it a bit, but it might cost you for them to keep adjusting it.
Get a boost guage fitted then you'll be able to see what PSI your pulling.
Just take it easy for a couple of week's you'll soon get used to it
cawsey18
158
yer yer , i shall call tommorow see what he says seems like a nice chap . I have already got a guage fitted . Standard was max of 10psi , now about 19 or around there then tapers of
cawsey18
158
i do mate yes . havent had it rr yet . The guys at the surrey branch dont have a rr there . The guy who did it sad he had alot of experience with these cars . He said with a few little things done to it decent aifilter. and a new air flow sensor . I should be achieving about 225 - 230 bhp and 255 ft pounds of torque . But as it stands he recons its about 215 and 240-245 ft pounds
D.K
LCR 225
Oct 24, 2007
6,408
se london
Was it Simon you saw ???
If you can try and get it down to Essex for a RR session,
Airfilter wise try modding your OE air box with a high flow panel filter.
Dont worry you'll get used to the boost
cawsey18
158
im not sure i didnt get hold of his name .. Yer i will do need to get an rr done just to see what i have . Im sure i will just have to take it easy for a while :D
D.K
LCR 225
Oct 24, 2007
6,408
se london
We might be doing another shootout day at AmD Essex towards the end of the summer so keep your eye's open.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
Takes a while to get used to the car after mapping.. try not to treat the accelarator as an on/off switch, feed the power in gently and smoothly. Ive not driven a car with an amd map but you proberly have a bit more power than the tyres can handle in the first couple of gears.
Youll get used to it, what tyres are you running? are they in good condition?
D.K
LCR 225
Oct 24, 2007
6,408
se london
Yes mate it's fine in 1st and 2nd, if you nail it really hard then it will wheel spin but you learn to controll your right foot.
My mid range torgue is very good and thats where it's at it's best ;)
