Boost Controller
Curious Chris
attention seeker
Sep 11, 2006
163
Hi can anyone give me some idvise, first of all a friend of mine has offered me his boost controller off his celica gt4, so basically i want to know
1) will it fit and
2) what power difference will i be seeing if i buy it
i have a leon cupra (180)
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
dont really work on our cars sorry, only one that does is the jabba one, unless you have done loads to your car it will mess with the ecu settings
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
In terms of fitting, I assume its a knob with 3 pipe connections??
If so this would fit but I would suggest you use a boost gauge to ensure you do not over do it... !!
My mate has had one on a Leon before, you need to remove the N75 in its favour, which puts the TC light on the dash...Not sure of the power advantage but its a bit dodgy if you don't know how much boost you are running.
Personally wouldn't take the risk but thats just me!!
Curious Chris
attention seeker
Sep 11, 2006
163
righto u just saved me £200 for the controller and alot more on fixxing the engine by the sounds of it :) oh why im here, jabba stage 2 or revo stage 1? im stuck on which one to go for
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
well documented mate, try a quick search,
but its down to your idividual prefrence!
you'd expect more from the Jabba because its a bit more custom,
wheas the Revo is a load on program!
