Bonnet Raisers
kieran_cupra
Yellow n Black works!!!!
Apr 15, 2006
403
Nottingham
nah its not the lifters im after , its a part that lifts the back edge (along the windscreen side) up allowing heat to exit , thus lowering under bonet temps
Kieran
kieran_cupra
Apr 15, 2006
403
Nottingham
wonder if they make em for a vw??
These would be a sound investment on those hoyt summer days, keeping te temps down
kieran
Prong
All the raisers ive seen on the web seem to be for fords. Might have abit of trouble in finding them. :confused:
Dan20vt
on a bonnet you have two 10mm bolts each side holding it to a bracket, if you take out one bolt each side and put them back in losely on the side of the bracket not into the bracket hole you will get the same look when you shut your bonnet...
kieran_cupra
Apr 15, 2006
403
Nottingham
right, well might have a look around and see what they look like. if they look pretty easy and simple, i might machine some up at work, and see how it goes.
Kieran
