Bolt instead of welding clutch pedal?
ian_jobson
272
Medway towns, Kent
has any one drilled the pedal and bolted through instead of re-welding the pedal? reason i ask is i have no way of getting it welded back up... done a search seen one person done it which gave me the idea, couldnt find much else...
MikeA
MAF Destroyer
Nov 14, 2005
92
Northants
To be honest mate i'd get it welded up. Most garages will weld it for you and it shouldnt cost you too much.
Bolt solution wont really be a problem although drilling through it might weaken it a bit.
May 25, 2004
2,691
Newport, South Wales
It's the way the clip sits on the end of the rod. Allows it to swivel a certain amount inside the box section. A bolt pushing against the rod won't do the same, I reckon give it a few months and you'll have a :censored: clutch cylinder.
