bog bone mount fitted
Mat138L
204
halifax
just fitted my mount and have noticed a lot more vibration through the steering is this normal its not bad you can feel engine more i have been told this is normal until the bushes bed in :shrug:.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
It does calm down, but if you'refeeling a LOT more vibration - did you torque the bolts up correctly?
YerMother
comes and goes
Sep 22, 2004
1,461
East Midlands Drives: Scirocco GT
You are bound to feel a lot more vibration because they are alot stiffer than standard! I had the EIP dogbone which was better (less vibration) but i think it was just a compromise! I have the Neuspeed bushes in now and the vibration when pulling away is slightly annoying, but just give the engine more revs to overcome it!
You soon get used to it! :)
Mat138L
204
halifax
yes thats what i thought its not bad at all and i thought it would be like this but allways good to check.:cheers: guys
Mat138L
204
halifax
RickC said:
what gains do you get?
a bit less wheel hop and it does feel like the car is more connected to the road and it feels like it puts the power down better aswell.I did try it with just the smaller of the two bushes installed and the seat one and it had no vibration that i noticed.What i am going to do is leave it for a week or so and then retorque it again just in case.:think:
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
ahh right, you lot really must hammer your cars enough to need all this stuff, or is it because your chipped, i know when i had the revo trial it was a maniac.
Ju.
461
Bradford
Can't say I really notice mine now,it's been on about 6 months, probably just got used to it
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Where abouts do these fit and roughly how long does it take to do?
Is it a garage job.
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Is it a garage job.
Underside of the engine / gearbox.
You will need a ramp or axle stands, off with the under tray and unbolt 2/3 bolts. (DIY around an hour, Garage 15 mins)
You can do it DIY but make sure you Torque the bolts correctly otherwise you get excessive vibration back through the cabin (steering wheel)
This is one of the best value mods I tried, I used the EIP version at £85 ish and thought it worked superbly
- Car felt connected
- Less work for the ESP to do
- Less nose lift under acceleration
After a remap it's right up there with a short shifter as probably one of the best value mod's on the market
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Are we talking about the same thing mate
The Powerflex Uprated Polyurethane Front Engine Mount Dog Bone on the Forge website, the two yellow spongy things about £20 :confused:
Ruddmeister
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Yes the Powerflex ones are Poly ones and they fit into the existing mount (take mount off car replce bushes and refix)
or
EIP do a fully redesigned mount at £85 available from Westec
http://www.eiptuning.com/eip/motormounts.html
to quote them
EIP motor mount does not use hard polyurethane found in most other mounts. Because of this, little to no additional vibration will be felt when using our mount
Pay your money and take your choice ;)
Ju.
461
Bradford
This is it:)
