BOC issues
Sep 12, 2020
So my sister purchased her first car alone! It a 2013 bocanegra.
Feels okay to drive but I thought is seemed to be low on pull.
First thing I noticed was no EML when ignition is switched on so I scanned it codes below:
Car Scanner ELM OBD2
DTC report
Selected brand: Seat
VIN: xxxxxxxxxxxxxxxxxxxx
============1==============
P10AD
Raw code: 10AD
ECU: Engine control unit
Status: Pending
============2==============
P0458
Raw code: 0458
Status: Pending
OBDII: Evaporative emission (EVAP) system, EVAP valve - circuit low
============3==============
P2088
Raw code: 2088
Status: Pending
OBDII: Camshaft position (CMP) actuator A, bank 1 - circuit low
============4==============
P0245
Raw code: 0245
Status: Pending
OBDII: Turbocharger (TC) wastegate regulating valve A - circuit low
Seat: Turbocharger Wastegate Solenoid 1 Low Voltage
============5==============
4531
Raw code: 0011B3
ECU: 01. Engine control unit
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear
Seat: P069100: Cooling Fan 1 Control Circuit Low
============6==============
4745
Raw code: 001289
Seat: Air circulation valve for turbocharger -N249 Short circuit to earth
============7==============
4663
Raw code: 001237
Seat: P192600: Auxiliary engine coolant pump relay
Short circuit to ground
Seat: Injector cylinder 1-N30 interruption
============8==============
2798
Raw code: 000AEE
Seat: P208800: "A" Camshaft Position Actuator Control Circuit Low - Bank 1
Seat: Full load warning lamp-K228; Control lamp for full load operation-K228
============9==============
2984
Raw code: 000BA8
Seat: P024500: Turbo/Super Charger Wasteg.Solonoid A Low
Seat: Connection of resistance transformer 2 and antenna on glass; Connection between impedance converter 2 and window antenna
============10==============
4235
Raw code: 00108B
Seat: P045800: EVAP System Purge Control Valve "A" Circuit Low
============11==============
4269
Raw code: 0010AD
Seat Toledo 2013 - 2018; Ibiza GP2 2016-2017; Ibiza 2017 - 2018; Toledo 2009-2015, Altea 2009 - 2015, Altea XL / Freetrack 2009 - 2015, Leon 2009 - 2015; Alhambra 2011-2018; Ateca 2016-2018, Leon NF 2013 - 2018; 5F - A-CUV , 5F - Leon; Mii 2012-2018: P003400: Turbo Charger Bypass Valve Control Circuit Low
Seat 5F - A-CUV , 5F - Leon: C1079F1: Geber für Querbeschleunigung
Signal Grenzbereich überschritten
Seat: Magnetic coupling for mechanical loader interruption
Anyone shed some light ??
