Eblis
I seem to have a problem with the bluetooth car phone kit and my Nokia 3110c phone.
The car and phone connected just fine as far as i could tell and all my phonebook entries were imported into the car.
When a person calls me I can see both the number and the name as long as I only have 1 number for that contact.
For contacts that have multiple numbers (I can add more than 1 number to the same contact: home work, mobile, ... and one of them is defined as the default number) i can't see the name of the person calling me. The car display only shows the number that's calling me. From what i could tell this only happens for contacts that have more than 1 number defined.
Also, when i try to call one of these numbers after browsing the phonebook the phone will not call the default number for that contact but another one - I don't know for sure if it calls the same type of number for all contacts but for one contact that i tested with, which has a mobile number (default), home number and work number it dialed the home number instead of the mobile (default) one.
Is there any way I can make the car dial the default number ? Maybe delete the other numbers from its phonebook ?
