Blower motor making noises
SuperV8
1,654
772
I've noticed my blower motor making some feint noises recently - from a cold start in the morning and when accelerating or turning.
If I turn the blower off there is no noise, when on and when I accelerate or turn I can hear feint rubbing/graunching noise.
Obviously the blower motor bearings are getting tired (10 years old and 140,000miles) - just wondering anyone else experienced this and had any success squirting some lube in their? or is it new blower motor time?
Think i'll try a squirt of some PTFE lube - as its only three screws & free and a new motor is not cheap!
nd-photo.nl
3,940
162
The Netherlands
youtube.com
I would just replace it. Once you gain access its probably only a couple of screws to get it out. On my CLS55 I replaced the blower and was greeted with this major difference :LOL: But that was a 2005 car, so even older.
AP1GczPXTye4DOb63i3A81XhnKKMj4B84RWpMRQ3xicqYRC4Y5hxCxlZjBe-wAZpCUKZ_0wua03e2LZQQQ2laguSZVslQDZECV5XQkvXkgaIUNyt7C4WwHQ_rmnhqVkIFt3xheUyzFm1_FajqdAoUv7AuHmb9g=w1920-h1080-s-no-gm
SuperV8
1,654
772
Really easy job on the Leon so I think i'll inspect first.
New blower motors seem quite expensive! Probably seasonal pricing, like heater matrix's - cheaper to buy them in the spring/summer.
  • Sad
Reactions: nd-photo.nl
SuperV8
1,654
772
The OE part (made by Valeo) 5Q2819021C is listed at £279 - and that's without the 'fan control' 5Q0907521E which is £217! (which I don't think I need)
The Valeo equivalent = 715298 which does seem to be available for more like £100 - and does look like the OE part from a picture.
I will take it out first and have a look - certainly not urgently required.
mty12345
4,020
628
bristol
I had a similar issue on my mk1, turned out some of the insulation had come loose and would rub on the side of blower.
R3k1355
1,849
269
Yorkshire
There's loads of 3rd party options, usually around 35 quid. Blower and resistor together.
Usually you would avoid the super cheap ones, but it's a 5 minute job to swap, if it only makes another 50,000 miles - who cares, slap another one in there!
