Bloody window..
jamiepyrite
147
So I've had loads of problems with my drivers side window dropping down into the panel sometimes when you closed the door. It well and truly screwed itself up the other day when the wire came off the pulley! So a trip to the scrappy and I've picked up the mechanism from another ibiza and some nice new clips (that go on the runner, that connect to the glass clamps) off a cordoba. Shall see if it all fits nicely tomorrow!
Another question: I was having a read of the Haynes today and it mentions a 1.8 Glxi model.. I've never heard of this before.. Are they rare and what are they like? I would really like a 2 litre ibiza but at this age (18) I doubt I can afford the insurance! So I figured something a bit smaller could make a difference..
Kai_1600
Shallow
Dec 10, 2005
410
Manchester
Good luck with the window!
I was in a similar boat at 24 :$ but having only just learnt to drive - I got a 1.6 SXE, obvioulsy no where near the perfmance but looked better from stock ;)
chappersno1
157
did your window rattle realy bad wen u use to shut the door?mine does and it tends to drop at the back slightly when u shut the window and stops.then got to lift the window square again for it to shut
u got the same probs?:shrug:
jamiepyrite
147
Basically, the problem with the window was this:
In the mechanism, you have the metal bars which go up, with the plastic runners attached to them. These plastic runners are attached to the metal window clamps on the bottom of the window. The plastic runner is meant to have clips on which secure to the window clamp but for some reason they decided to make it out of the worst plastic ever. Which snaps incredibly easy so all the securing clips snap off.
If I closed the door with the window own at all, it made the window clamp jump off the runner and fall to the bottom of the door panel. The problem is, I know that eventually they are just going to snap on my new mechanism!
Surculation: Five minute job for me and my Dad!
I've also had to steal a load of the little clip things off the Scrappy's Ibiza for the door card. As they are only glued on to the inside of the card and from having to take them on and off all th time to sort the window, most have fallen off!
Just took a picture of the Haynes page. :)
