2footpegs
117
was out driving today enjoying my new CC remap when all of a sudden i hear a crack and then my clutch pedal goes staight to the floor, i pull over and see a black broken clip and a white clip on the floor and theres jus no resistence in my clutch pedal, had to get towed home by the AA who said my master cylinder has siezed. does anyone kno how much these cost to fit also i heard that the slave cylinder could also be the problem, how can i tell whether its the master or slave that needs changing. thanks
Mikey P
The Flying Custard
Mar 4, 2009
193
Manchester
aparently according to the sticky at the top its a common fault for the master to go,so i think for a change the AA guy mitght be rite lol
jwfcms
384
UK Yorkshire
the broken clutch pedal clip is common. just get a new one fit it and try it first before replacing master cylinder. probably find a guide somewhere on here or vw vortex, would be all same set up near enough
2footpegs
117
yh thanks for that but i think it more than just the clip as you can see the rod on the master cyilnder is slightly bent and does not budge at all im jus hoping i dont need to change the slave aswell or that this has hapend because the slave has failed
jwfcms
384
UK Yorkshire
have you had the clutch replaced at all before along with new slave ? well take it one step at a time then just go for the master and the clip first. bleed the system with a pressure bleeder. best way to do it.. it uses tyre pressure and a resevoir piped up to your brake fluid cap/resevoir and pushes the fluid through just a matter of opening the bleed nipple on top of the gearbox/slave cylinder and letting the fluid out untill there is no air.
2footpegs
117
no havnt changed the clutch or cylinder before as the cars on 60k but probly will need doin soon, yh im change the master 1st jus a pain cuz i have to get it towed to a garage plus i jus spent £450 on it last week gettin the reamp, THS TIP and panel filter. so a big bill aint gonna go down to well
2footpegs
117
yh i kno lol, na bought back in january, nothing to majors happend so far so fingers crossed itl stay that way
