Bleeding the cooling system¿?¿?¿?¿?
amadain
hi all
Are there any points in the cooling system where i can bleed air from? My haynes manual doesn't mention a thing about it
ste4232
141
with expansion cap off squeeze top hose till you get good flow back into tank (with engine running long enough for stat to be open)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
and make sure the heater is set on hot
that way you wont get air locks in the heater matrix
Stu_HR
Odd Member
Jun 9, 2005
293
Try a coolant change on a Citroen AX where the filler tank is lower than all the coolant pipes. Brilliant design [:@]
