Hi,
I've read a lot of VERY GOOD TOPICS talking about bleeding brakes
I've just not seen any when replacing many parts and the system is finally dry.
First I have a Golf 4 1.8t with ABS MK60
I have VCDS and a motive power bleeder
20L of DOT4
Brand New MC
Used ABS ( get this one because mine doesn't push fluid to the rear brakes I don't know why )
Once ABS and MC replaced, I supposed that :
1) fill the entire system with the power bleeder at 1bar max (if MC used I think)
2) bleed all 4 corners in this order : RF LF RR LR (reverse order for a MK60)
3) NOW should I at this time, bleed the MC nor clutch ?
If yes, please tell me the order
(When the MC is attached, what is the front and rear bleed nipple ? And which one first should be opened ?)
4) Then to bleed the ABS, some guys first do with VCDS the ABS procedure, then the output test for each corner, then a normal bleed and finally again the outpest test
Is it right ?
(Normal bleed should be MC or CS first then the 4 corners ?)
5) After this should i again bleed all 4 corners and MC and clutch ?
Finally if you have any topic that indicates how to adapt the new ABS (already used not a brand new), it would be awesome
20L of DOT4
Brand New MC
Is it right ?
