Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
OK, so ive lost all fluid out of brakes due to a small problem with pads, any how, now im ttrying to re-fill the pipes etc...... can any one give some helpful tips on how i should go about doing this? do i need to bleed 2 whells at once or can i do it one at a time?
pressure bleed or vacuum bleed them keeping resevoir filled the whole time, working your way around the bleed nipples front rear and clutch m/c if the whole system ran dry.
Rubber Bleed Tubes From Any Car Parts Shop Allow Single Handed Bleeding
I Suggest Bleeding The Two Rear Wheels Together
The Golf Has A Balancing Valve On The Rear Brake Pipes That Makes It Difficult To Bleed And Get A Hard Pedal Without Doing Them Together
Cheers Guys for help, decided to take it to seat 2moro, said they would do it for £18, so cant complain at that (using my fluid) so save myself lots of hassle, thanks for the advice thoe.
