bleeding brakes
pedro-tdi
hey my mate has a fabia vrs which he fully stripped and painted weve put it all back together but carnt bleed the brakes, weve tried and therse fluid at every nipple but he pedle has nothing there and carnt see any leaks. any help appriciated.
Neo
Fool member
Mar 24, 2009
881
I'd get in there with a pressure bleeder like good old Gunsons Easibleed - but keep the pressure down a bit.
I just got one for when I put my 312`s on... as apparently you should`nt use the conventional two-man pedal pumping method on certain VAG cars... plus I`ll probably do it on my own anyway.
Looks like a great bit of kit, can`t wait to use it.
Yes the instructions recommend less than 20psi is used, I`m going for more like 10psi I reckon.
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
I know its frowned upon, but on my leon we cracked off the nipple on the master cylinder a little and that solved everything.
Just be careful!
Jimski
