bleed valve?
Dan_Cupra
61
can you fit a bleed valve to an ibiza cupra? any1 ever done it? would there ever be a case id need to ? as i no the boost is controlled via ecu.
Spud_G40
PS3 Gamer tag: SRedx
Jun 12, 2006
397
Glasgow
I run one also, more or less because I have to with my setup.
Don't turn it up past what parimeters are setup on your map on the ecu, it will only go into limp mode.
Running one with a remap to suit i'm sure will have its advantages though.
