Hi all, the Mrs owns a Mk2 (2007) Leon FR TDI 170..
Had it around a year with no issues until now.
It was a one owner car with 152k & FSH
Drove mint when we went to buy it, couldn't knock it on a thing except for a bit of paintwork on the front bumper and a rear quarter.
Anyways,
Got a problem that no one can get seem to get tot the bottom of !
It stated off a few months ago by throwing a bit of blue/black smoke out of the exhaust when you first started it in the mornings, and it would tick over a bit lumpy for around 7 to 9 seconds then level off and tick over perfect after that, then it would run fine all day and not do that again till you started it the next morning.
Then about 3 weeks ago,mother mrs rang me and said it had just lost all its power and it was chucking out thick black smoke out of the exhaust..
When I got home, I went out in it and it was dead and I couldn't see any cars behind me in the mirrors it was that bad..
I'm not in the dark about engines myself, and it looked like egr issues the kind of sooty smock it was chucking out, it was that bad, you could see big particals of soot floating in the air when you revved it up.
So I took the egr off to see if it was stuck open which it wasn't, so I cleaned it out while I had it off and put it back on with no difference. So I blanked the egr pipe off at both end with metal plate and still got no difference.
I've plugged it in to Vag-Com & a solus ultra which both are coming up with no codes..
I've give it to 2 garages and they both said its gonna be the injectors with the miles its done, and I should do them first..
So I took it home, and while I drove it home, I pulled over, lifted the bonnet and unplugged the air flow meter. I got in the car again and driven it and it was back up on its power and the smoking stopped,, I thought "Buzzin", driven it around for a few hours like that and it was fine, so I got a new Geniune air flow for it. Stuck it on and it was was exactly the same again, dead/no power and smoking like hell..
Right, I'm going to put a list of what it's had, any advice/input would be great, as it's had a £1000 spent on it on bits upto now and it's the same.
It's had the air flow on it
Sensor on front lower boost pipe
Set of injectors
Injector harness
A turbo
All vac pipes have been checked for leaks
It's still the same !
We have just noticed that the dpf has been cut open and had the insides taken out.
So I looked into that a bit more and got hold of the previous owner and he told me that he had the dpf removed and it was mapped out of the ecu, don't know if it's got anything to do with the problem, but thought I would let yous know before someone suggests to have it removed !
The car is really doing my head in now, it's blowing my brains out !
Any advice would be great or to hear off someone that's had the same problem and got to the bottom of it?????
I've been thinking if it could be a problem with the ecu coz it's had the dpf mapped out of it, just wounding of the map has corrupted or something ?
How someone can help !
Oh yea, the engine code is BMN
Got a spare set of injector aswel if anyone needs a set ! Lol
Anyways,
Set of injectors
Injector harness
A turbo
