RD design in Germany do them all but pricey.Hi, I have a 2016 Cupra 290 and am after some black SEAT badges front and back. Just wondering what are the best options. Anyone got pictures of theirs and where they got them from?
Cheers,
Brandon
I had front wrapped, but rear boot badge was a PITA so bought a painted one from said company. Wasn’t cheap, about £100 delivered.
Plastic dip them, basically is a sticker then so can peel off when you need to, thats how I've done mine. just make sure you mask up the surrounding area well enough so don't get it everywhere and put enough coats on so that it does peel off correctly when it comes to taking it off. tin of black is about £10/15ish plenty to do front and back. loads a vids showing how to do it on Youtube.
Yeah good shout, make sure its the good stuff.Make sure you buy genuine usa plastidip and not the UK stuff being sold on ebay by plastidipuk.
The USA product is far superior, goes on thicker, looks better and lasts longer.
Cheers mate I’ll defo be looking into itPlastic dip them, basically is a sticker then so can peel off when you need to, thats how I've done mine. just make sure you mask up the surrounding area well enough so don't get it everywhere and put enough coats on so that it does peel off correctly when it comes to taking it off. tin of black is about £10/15ish plenty to do front and back. loads a vids showing how to do it on Youtube.
WHAT THE ACTUAL ****! How many times does he actually say the same thing without actually saying anything new! That video could of been 10 seconds long!!!!! And why is it better? He never says or shows you. Honestly that video is about as helpful as a spade in keyhole surgery.
And that is what the video should of said Rather than spend 4 minutes showing you the difference in the canI have bought both and the UK stuff is crap in comprassion. It does not spray as with the same thick texture as the USA. The result of this is when it comes to peeling off the excess around whatever it is that your spraying, the UK product usually results in the excess material not tearing cleanly around the edges of what you have sprayed
Alot of sellers of the UK product try to pass it as the USA product.And that is what the video should of said Rather than spend 4 minutes showing you the difference in the can
