Bigger MC for Mk2?
Icecavern
6,214
Berkshire, UK
www.icecavern.com
After fitting the brembos I'm thinking the pedal travel could be reduced by fitting a bigger master cylinder to my Cordoba. Is there a bigger one that I could fit easily as I like the short travel on the LCR brake pedal, be nice to get that in the cordy :D
Pete
Icecavern
6,214
Berkshire, UK
www.icecavern.com
Does anyone know if a Leon master cylinder will fit a Mk2 Ibiza/Cordoba servo? According to vagcat.com the MC on the Cordoba is 22.2mm where-as the Leon one is 23.8mm.
Just wondering if fitting the MC out of a leon will reduce the pedal travel?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
theres a 23.8 listed for abs ibiza/cordoba
theres a different master listed if you look under the abs section
in fact i possibly have one here as i could only get a 22mm one when i suspected mine had flipped seals and im sure it listed 23 on it - in teh end my abs was blocked so didnt really need a new one anyway but left it on like everything else :)
ill dig it out later and measure it to check
