Switched my car on friday night, drove a little way down the road. looked at my dash and saw that i had the engine management light, the EPC light and the traction control light on. car was running fine. i turned it off and started again to see if they went away but no.
carried on driving, car still running fine, then i started to lose power. the car started to run very very rough. pulled away in first gear and had no power at all, the throttle pedal did nothing but the car carried on at about 10mph.
limped it back home, plugged in my laptop to see what fault codes there were.
came up with ,
THROTTLE CONTROL VALVE ERROR.
I'm not using VAGCOM but a diagnostics programme my dad has on his laptop he uses at work.
I spoke to a guy who had the same problem on his passat and he reckon it was a dodgy connection on the sensor on the throttle pedal.
My car is a 2000X reg cupra, running stage 1 Revo and a BMC panel filter.
Anyone on here had this problem or can you shed any light?
Hope it made sence.
Thanks in advance.
came up with ,
Hope it made sence.
Thanks in advance.
