Best petrol to use
taff141177
388
crewe
I ve heard v power is probably one of the best petrols to use the thing is I haven't got a shell garage nearby can any one recommend any other unleaded fuel to use instead of ordinary unleaded
taff141177
388
crewe
Nice one yeah think Tesco has got the 99 momentum I've been using normal inleaded in mine for a year now and think its about time I started to use a better quality since a few others have said about using v power
BigJase88
Jase
Apr 20, 2008
3,765
1,074
I use momentum
And its not really a scam. My 1.4tsi requires at least 98ron as it has a supercharger! 95 ron retards the engine :O
Feb 26, 2009
5,275
Wolverhampton
I use momentum
Its not 'just' because its supercharged, many supercharged cars work fine on normal fuel. Its whether the map has been written to take advantage of super unleaded. My v5 is nowt special, but because it was designed to use super it has trouble with normal.
Put it in a car that can't use it and all you're doing is wasting money. So that is probably where the 'scam' thoughts come from.
5,275
Wolverhampton
My old mk2 tfsi specified 98 ron on the flap so nothing to do with being mapped
Most Cars Probably, just making the point that some unmapped Cars need 98
Yeah, so it was mapped by SEAT to run on 98. As Traumapat says, I'm not talking aftermarket 'remap', I'm talking standard factory map. All fuel injected cars have a map of some kind. Sorry if I confused the issue. :)
To get the most out of super unleaded, it needed to be burnt earlier in the cycle. If the map doesn't allow this, then it'll just get burnt at the same time as normal fuel and the extra energy will be wasted. Whether the car uses forced induction or is naturally aspirated, the fuel still needs to be burnt earlier than normal fuel would be.
Of course, if you burn normal fuel that early in the cycle it runs out of energy before it's able to push the piston down. This is pre-ignition, which is what a knock sensor is designed to cope with. If the knock sensor picks up pre-ignition, the ECU retards the spark so it can run on normal fuel, albeit with reduced output.
Mr OCD
1,974
Manchester, UK
I've run mine for over 60,000 miles on v-Power / Tesco 99 ... I prefer v-Power simply down to the cleaning agents in the fuel which is good for the engine.
