beeping sound
becketttimmay
oright can anyone help me with this before i take things apart,, whenever i turn the ignition the computer makes a bleeping noise as same a seat belt warning, and low fuel!! how do i stop this,, is it to do with resetting the system?? faulty wires?
cheers
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
is there a light flashing on the dahs.....by the temp?
if so its the sender in your collant bottle either knacered or just needs scraping off with a screwdriver...happened with my old mk3...
just open up the coolant bottle (when cold) and you will see 2 prongs of metal, scrap them with a screw driver a bit!
See if that helps?
merlin051
Oil Burner!
Aug 22, 2006
186
North East, Darlington
Vag-com it.
I'm not sure but i think they possibly beep when due a service, also displays "Service" on the dash.
I'd Definitly get it vag com'd though to check. Does it still beep when fuel light comes on?
