Beep, beep, beep.... a NEW beep... Temperature Gauge
slimjim
Professional Muppet
Feb 1, 2005
1,172
Telford, UK
www.jameshardacre.com
After mentioning it on another thread... but temp beep is back.
-0.5 this morning.
Started the car with the rear window on, no heat on the blower....
My water temp light started flashing and I got a new beep in sync wit hthe flashing. I have done a quick phone video, but the beeping stopped before I could record it. Although the temp light kept flashing for a while.
Anyone had this before? Know what it is or why its doing it? :shrug:
alock
52
I often get this on a very cold morning (but without the beeps, or maybe I'm just to deaf to hear them). I restart the engine and everything if fine. I've put it down to a temperature sensor sticking or some condenstation frezzing somewhere :confused:
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
My whole climate control screen has begun to flash every so often when I start up now. Carrys on for a few seconds and then goes back to the normal settings :shrug:
muddyboots
Still hanging around
Oct 16, 2002
5,739
Mine did it once every now and then, maybe 4 or 5 times that I noticed in all over about 3 years. Never did know what caused it, but there seem to be no ill effects, still works fine.
zidane
My Cupra TDI started doing this 2 days ago. Did it again this morning. It was -4.0 degrees
It didn't beep this morning - just a red light, but the Mrs said it beeped for her.
Was going to go to dealer but can't be arsed now I've read this (good timing!)
I reckon it will be fine when this cool snap passes.
Riddick_m3
339
Sudbury, Suffolk
mine flashed for the first time yesterday on the lcr i presumed it was a warning of some sort that the engine was to cold to drive and so i waiting untill it had been running 3 mins before i drove off, i restarted it and it went out , i think the outside temp said -4 c
AL-TDI
AL-TDI
May 10, 2005
34
Walsall West Mids
I had the same thing it only happened on very cold mornings turned out that the coolant was at the min marker topped it up and it hasnt done it since.
